M84 inputs Diagnostics off
Postby Gaston on Sat Feb 18, 2012 6:19 am
Hi guys !
In newer firmwares releases
Would be a possibility to "turn off" not used inputs? to avoid Errors on diagnostics panel , with racing cars, I never connect anything like MAF, oil press and other sensors.
Cheersss !!
Gaston Scazzuso
whatsapp: +54(9)11 5385 1996
mail: soporte@moteclatinoamerica.com
Gaston
Re: M84 inputs Diagnostics off
Postby PQatPIT on Sun Feb 19, 2012 6:39 am
Gaston wrote:..., oil press and other sensors.
I would never leave fuel pressure, oil pressure and oil temp unconnected! Very much needed with racing engines.
Btw, sensor setup gives you possibility to turn off unconnected sensor false alarms.
See: Adjust -> Sensor Setup -> Input Setup... -> Warn Lo / Warn Hi settings.
PQatPIT
Postby Scott@FP on Tue Feb 21, 2012 5:31 am
For unused inputs, set Diag Lo and Diag Hi beyond the normal input range, for a 0v-5v sensor set Diag Lo to -.1v and Diag Hi to 5.1v, then it will never go into fault.
Scott@FP
Postby MarkMc on Tue Feb 28, 2012 1:24 pm
This is on the list of things to do for the m84.
Postby Gaston on Tue Mar 27, 2012 1:25 pm
Oki Great !.. Thank you !! and Sorry about my ignorance ! :?
Gaston Scazzuso
Gaston
Return to M84 ECUs
