M4 Pro too rich at idling unable to reduce
Postby wenya on Mon Feb 20, 2012 1:40 am
Hi
this is my 1st Motec ecu M4 pro
my engine setup as below
SR20det
GT3076R turbine
FIC 1050cc low ohm injector
Greddy intake manifold with 70mm throttle body
big FMIC kits
std cam shaft
walbro pump with 20psi w/vacuum
the problem is the air fuel ratio too rich (11af ) at idling after I change my 510cc injector to this FIC 1050cc injector .
I know we can reduce it at fuel map right , but even I reduce the loading point ( idling ) to 0 it still too rich .
but once the vacuum loading point near to 0 vacuum everything go find .
the problem stared when the loading point go below -0 vacuum .
can anyone here help me out of this problem .
Thanks a lots
wenya
Re: M4 Pro too rich at idling unable to reduce
Postby stevieturbo on Mon Feb 20, 2012 8:17 am
Have you adjusted the settings in the Motec for the new low impedance injectors ? ( assuming previous were high impedance ? )
And are you operating fully sequential injection ( ie you have a crank and cam/phase sensor ) ?
Also, not that it should affect this, that throttle body is huge for that engine.
stevieturbo
Postby stevieturbo on Mon Feb 20, 2012 8:19 am
wenya wrote:Hi
Please clarify what you mean by that. Because 20psi is a totally ridiculous fuel pressure to be using in an efi car. it is far far far too low.
IMO never go less than the typical 35-40psi or so ( with vvac )
stevieturbo
Postby wenya on Tue Feb 21, 2012 1:32 am
stevieturbo wrote:Have you adjusted the settings in the Motec for the new low impedance injectors ? ( assuming previous were high impedance ? )
yup set it to low impedance
yup fully sequential injection
for the 70mm throttle because we are looking for 480whp for this motor , ( a pair of Tomei Procam 270 is ready to drop in once settle the fueling problem )
wenya
Postby wenya on Tue Feb 21, 2012 1:38 am
stevieturbo wrote:
wenya wrote:Hi
yup I know it is very low for EFI motor ,
but if I set it to 30psi it will much much too rich at below 10A/F you see.
and at the fuel map it is no way to reduce anymore ! even go as low as 0 value it still too much fuel .
is there any other way to reduce it ?
wenya
Postby stevieturbo on Tue Feb 21, 2012 3:43 am
70mm TB will support double that power.
And the injectors will never work properly at such low pressure which could be contributing to the problem. They will just dribble fuel out, not spray it as a fine mist as is required.
What are your actual injector pulse widths at idle ? Are they wired correctly in firing sequence ?
And fitting bigger cams will only make the situation worse, so you really need this sorted first.
In the picture, the first injector looks like the seal is not fitted correctly, are they all like that ?
Restore fuel pressure to a sensible level, then try and tune for an idle at say 2000rpm and see if that works. If it does and you have control, perhaps adjust injection timing to see if it helps and then reduce the rpm's slowly
Although if you have a zero in the main map and the engine still runs, something else is badly wrong. The engine should stop, as no fuel should be injected. So confirm there are n strange settings within the ecu and confirm at zero fuel pulse widths are zero.
stevieturbo
Postby Holmz on Tue Feb 21, 2012 7:49 am
stevieturbo wrote:...
How do you set the dead time for the injectors?
Holmz
Postby wenya on Wed Feb 22, 2012 2:45 am
stevieturbo wrote:70mm TB will support double that power.
wiring all correct
will fix the fuel pressure and try it out .
the injection timing is RPM 1000 ~250 , RPM 1500~275 at the moment .
the pulse widths is 0.2 at idle .
I'm not going to install the cam yet , now trying to get the idle done 1st .
wenya
Postby wenya on Wed Feb 22, 2012 2:48 am
the dead time is 12v ~1140, 13v~1060
wenya
Postby Holmz on Wed Feb 22, 2012 7:36 am
I would suggest that you need to measure that yourself.
if you wind that right back to zero, and wind back the fueling cells at idle to zero, then it should not be running rich.
Holmz
