Subaru Spec C ECU Tuning Problem
Postby Gepesz on Fri Feb 10, 2012 3:50 am
Hi everyone,
I am Gepesz.
I am a new the MoTeC forum.
I have a Subaru Impreza 2002 Spec C (not twin scroll turbo but also VF 34 ball bearing turbocharger) with Motec M800 (advane function, Lambda traction and launc control and 1M log) , SDC3 diff controller and Sport DAS Display. The M800 and Das communication with CAN .
The engines is origin Spec C.
I modification:
-Intake APS cool intake
-Equal exhaust manifold
-2,5" exhaust
-Blitz BOV
I am initial MoTeC ECU writer. I need a base file my ECU because I have a base ECU file but the car is not work good. I have a lot of plus sensor (brake front and rear, exhaus temp,fuel press, oil press, oil temp, rear diff temp and gearbox temp,). The sensor is calibrated and sensor setup is OK. The Das and M800 I see the correct value.
If someone can help me please help .
Sorry my English. I am studying now. :oops:
My email address: gepesztuning@gepesztuning.hu
Gepesz
Re: Subaru Spec C ECU Tuning Problem
Postby MarkMc on Fri Feb 10, 2012 4:44 pm
Can you send me the serial number from the factory Subaru ECU case and the serial number of your M800. We match the start files to the Subaru number.
Postby Gepesz on Fri Feb 10, 2012 9:56 pm
Hello Mark,
I use this file. The file when I use I write.
I have some problem with:
-Cold engine start
-Idle
-Injector timing and duty (I use a original Spec C injector 550CCM) hight RPM is injector duty more 100%
-Bost control (in 6th gear is too much pressure higher then 1,5bar)
-hight EGT 900C ( I measurement temperature UP pipe under turbocharger)
Thank you for your help.
Regards Zoli
Gepesz
Return to M800 Plug-In ECUs
