Problem with Gear Detection on USDM EVO 9 MR
Re: Problem with Gear Detection on USDM EVO 9 MR
Postby anthony_hk2001 on Mon Jan 02, 2012 2:05 pm
Yes, the MDC offers lots of advantages such as all four wheel's speed. The GPS from CDL3 will give me the ground speed.
anthony_hk2001
Postby Scott@FP on Fri Feb 03, 2012 12:03 pm
I went and revisited this, and it doesn't seem to matter whether you use a diff ratio or not, correct gear gets calculated instantly. Seems that as long as the gear RATIOS entered are close to being correct, doesn't matter if its primary ratios only, or not including final drive, still works.
However you do need to turn on TC/LC (Mx00), otherwise gnd/drv speeds are not calculated and stay zero.
Scott@FP
Postby anthony_hk2001 on Sun Feb 05, 2012 8:29 am
Actually I had that sorted out already and its working now, thanks.
anthony_hk2001
Previous
