SDL dash to LIFE F88 ECU
Postby busaman on Sun Jan 08, 2012 5:37 am
Does any one know the settings or is there a template for setting up comms between SDL dash to LIFE F88 ECU its all wired in just how do i make them talk to each other.
busaman
Re: SDL dash to LIFE F88 ECU
Postby JamieA on Mon Jan 09, 2012 2:15 pm
I must say that I have never seen a Life ECU here in Australia.
Ill ask the MoTec Europe guys if they have any info on this type of ECU.
regards,
Jamie
JamieA
Postby busaman on Mon Jan 09, 2012 7:04 pm
ok thanks jamie it will be the same as pectel sq6 and syvecs s8 it is effectivly the same ecu.
busaman
Postby stevieturbo on Tue Jan 10, 2012 7:32 am
Have you tried asking Pat/Syvecs, or over on the Syvecs forum ?
stevieturbo
Postby busaman on Tue Jan 10, 2012 9:52 am
not as yet i only registered today.
busaman
Postby AlanB on Tue Jan 10, 2012 9:45 pm
The attached ADL2 file has a set of LIFE F88 templates in it. You can save them from within ADL2 Manager then move them to the SDL comms directory to make them available from within SDL Manager.
As the SDL only has 6 CAN slots, you will have to pick and choose which templates you use as there are more than 6.
LIFE F88 ADL2 LMP.D45
(234.42 KiB) Downloaded 1523 times
Alan Bell
MoTeC Europe Ltd
AlanB
Postby busaman on Wed Jan 11, 2012 2:47 am
thank you very much alan.
busaman
Postby busaman on Tue Jan 17, 2012 6:05 am
AlanB wrote:The attached ADL2 file has a set of LIFE F88 templates in it. You can save them from within ADL2 Manager then move them to the SDL comms directory to make them available from within SDL Manager.
alan is there a particular way to save and install them, i can see them in adl manager but the ones in sdl manager seem to be a different file type.and dont show up when i open sdl manager.
dave
busaman
Return to ADL, ADL2 and SDL
