RossB wrote:There are tables for Up Shift DBW Position and Down Shift DBW Position in the Gear Shift function. You need to set up the Gear Shift function even though you might not want the ECU to actually do the gear shift itself.
Fast_Moto wrote:I understand that on the R1, the throttle cable limits how far the throttle can be opened by the DBW motor, but the throttles are turned by the DBW motor. One issue is that in this configuration, the DBW motor cannot open the throttle bodies any more than the throttle already indicates (i.e. if the driver wants 70% throttle, all you can get is 70% (or less if so desired by the ECU). I don't know if this throttle body can be modified to be entirely cable operated.
Do you need to use this throttle body, or could you use a different one also?
IDP wrote:It would be possible to modify the safety linkage to drive the butterfly shaft directly from the cable pulley but you would have to disconnect the motor drive.
If you wanted to use the motor as a kicker it would need quite complex drive setting up.
I'd suggest it simpler just to use it in DBW configuration as original. That way the blip that you need is very easy to do with the gear shift function in the ECU
IDP wrote:No you don't need a sewing machine pedal.
You operate the throttle cable as normal, the pedal sensor is on the throttle body.
Yes, you have to pay for the DBW in the ECU but you end up with a nice system with endless possibilities.
Non linear throttle maps, Adjustable engine braking, Gearshift blipper, DBW based traction control, Idle control Etc...
http://www.sportrider.com wrote:When it comes to ride-by-wire throttle, things get a little complicated. The ECU controls the throttle bodies' butterflies, and the implication is that the throttle itself has no physical connection. But on the Yamaha YZF-R6, an interesting arrangement between the servomotor working the butterflies and the throttle cables means the closing cable still physically closes the butterflies and won't allow them to open more than the throttle is opened. I haven't had a chance to look closely at either the Honda VFR1200F or BMW S 1000 RR ride-by-wire setups, but the proximity of the throttle cam to the butterflies and servomotors on both models leads me to believe there is still some form of physical connection there. And I'm certain that other ride-by-wire models offered in the future will be likewise equipped.
="http://www.sportrider.com/features/146_1009_motorcycle_ride_by_wire_throttle/index.html#ixzz1iq4VhEOg
