GPS-L10 / OUTPUT Format
Information about using GPS units with motec devices
Postby Jakob on Fri Jan 06, 2012 6:24 am
I need a 10-Hz-GPS for my University-Project.
I'm wondering what Format the output of the GPS-L10 is. Is it NMEA or something proprietary?
Thanks!
Jakob
Jakob
Re: GPS-L10 / OUTPUT Format
Postby Jakob on Fri Jan 06, 2012 6:31 am
OK ... found the information in the data sheet :)
RMC, GGA (MoTeC default)
Is it possible to change this?
Jakob
Postby Jakob on Fri Jan 06, 2012 6:41 am
What's the rs232 data format for the GPS-L10?
x-data bits, parity, stop bit?
Jakob
Postby JamieA on Fri Jan 06, 2012 12:08 pm
The GPS-L10 RS232 output format is a standard NMEA output format.
RMC
GGA
The baude rate is 38400
you shouldnt need to worry about the other settings, but it is
8 data bits
1 stop bit
No parity
No flow control
JamieA
Return to GPS Information
