what is considerd best for the traction control aim compesation table
throttle posistion or lean angle?
I found this sensor which can be used for lean angle
http://www.pennyandgiles.com/Sealed-Tilt-Sensor-pd-37,3,,.php
sphilips wrote:what is considerd best for the traction control aim compensation table
sphilips wrote:i have found that the bmw s1000rr has a lean angle sensor. So traction controle doesn't work unless you have xx degrees of lean angle.
It is for motorcycle's that I want it.
is it possible to use a gyroscope with the m800?
FoxPerformance wrote:we have tried IMU's on our racebikes last year in AMA superbike and could never get them to work properly.
the interference from the close proximity to the ignition caused the problems.
