Help on Timer setup
Help on Timer setup
Postby whrdnsx on Sun Dec 04, 2011 9:37 pm
I'm wondering if its possible to have a timer set on a certain Throttle positon or Map position to run a PWM on an Aux table.
The Help says it has to be set to a status channel/switch. any way around this.
whrdnsx
Re: Help on Timer setup
Postby Scott@FP on Tue Dec 06, 2011 8:53 am
Use an aux, ign or inj output to trip Dig1-4 or an AT switch (loop a wire from aux/inj/ign to the Dig/switch) by pulling it to 0v.
The aux/ign/inj table is your table with selectable axis, your digital or switched input is set to Monitor, then set the timer to be started when that dig/switch is active. Be sure your polarities and logic are correct. Then this timer output can be used on almost any available axis.
Scott@FP
Postby MarkMc on Tue Dec 06, 2011 4:15 pm
If you can give me a little bit more detail about what you want to do I may be able to give you some other ideas. There is a full throttle timer as well which can realistically be set at any throttle position.
The devil is in the detail, how do you want it to start/stop/reset?
Postby Scott@FP on Wed Dec 07, 2011 3:28 am
MarkMc wrote:The devil is in the detail, how do you want it to start/stop/reset?
Ain't that the truth. Some crazy convoluted timer functions can be implemented.
Scott@FP
Users browsing this forum: Baidu [Spider], Bing [Bot] and 8 guests
