Motec's "Virtual Engine"
Re: Motec's "Virtual Engine"
Postby Chris Wilson on Fri Dec 02, 2011 10:07 am
Ben-S wrote:If all you want is a basic ref/sync signal you can generate a suitable output form a parallel port (printer) if you have a computer that still has one. I do this on a desktop computer for my injector flow bench.
I am a bit of a Luddite, most of the computers here have a parallel and true serial port, please tell me more, thanks!
Chris Wilson
Postby AdamW on Fri Dec 02, 2011 11:09 am
If you search google for "signalgen.zip" you will find the parallel port program on another ECU manufacturers site. There are also other applications where you generate a audio file and use this to trigger your ECU through your PC soundcard/speaker: http://www.megamanual.com/router/crankwheelpulser.htm
Also, another low cost option is the JimStim: http://www.diyautotune.com/catalog/jims ... p-178.html
Motorsport Electronics Ltd.
AdamW
Previous
