Is a baro fuel comp of "double pressure double fuel" applicabe to the following Effcy (fuel) calculation methods:
1. Throttle Position?
2. Manifild Pressue?
3. MAF sensor?
Example: Normally aspirated engine at sealevel and and same engine at 1500m Altitude
Baro Reading at sealevel 100Kpa, 85Kpa at 1500m
Would all the effcy calculation methods require a 15% addition in fuel when the pressure rises from 85Kpa to 100Kpa?
I know the VE of the engine will change slightly because of the increase of exhaust pressure and a lot of other variables, but that`s not the reason for my question. My question is purely about different Effcy calc methods and if the all require the +-15% Fuel increase as the air desity would be about 15% more
