ok let me rephrase....or see if I understand it correctly...... the 4 (or 5) bar map sensor isnt by default in the program, it has to be setup as user defined.... now if a ecu is setup to run the 300 map sensor (3 bar) and you use a 4 or 5 bar sensor..... wouldnt the output curve of that sensor be different given that the ecu already will be using the default values from the 300 (3 bar ) sensor?
or am i understanding this all wrong?
also.... in the load sites selection I am set to user defined.... how do I see that table?
