ATEN USB-to-Serial Converter
Postby robbie on Tue Nov 22, 2011 3:43 pm
I cannot establish connection to the ECU (M48) on laptop running Windows XP. Motec software Version 6.2
Laptop InstallShield Wizard has loaded software for the USB-to-Serial Converter as per instructions.
Connection with ECU is no problem with older laptop running Windows 98 (without USB-to-Serial cable).
Can anyone help.
Thanks.
robbie
Re: ATEN USB-to-Serial Converter
Postby stevieturbo on Wed Nov 23, 2011 2:55 am
Have you set the virtual COM ports up in system devices ?
You'll need to assign COM1 to the USB adaptor or it will never be seen. Or another COM port that the Motec software is able to look for.
And some USB-serial adaptors work better than others. It's just hit and miss really.
stevieturbo
Postby robbie on Wed Nov 23, 2011 7:38 pm
Good one stevieturbo, it worked.
robbie
