Audi S2 5 cyl
Audi S2 5 cyl
Postby insomnia on Thu Nov 10, 2011 9:24 am
Hello together,
i search the calibration table for the stock sensors for an Audi 5 cyl 2,2 Turbo.
Air Temp, Water Temp etc....And can anyone confirm that the Mode 59 is right?
Any advice or experience?
Thank you
insomnia
Re: Audi S2 5 cyl
Postby OmarK on Fri Nov 11, 2011 8:36 am
Which ECU are using on this car? If you are using a newer 'Hundred' series ECU then you will be able to do a ref/sync capture which will help you identify the correct mode for the car. There is a webinar that you might like to watch about this function...
OmarK
Re: Audi S2 5 cyl
Postby insomnia on Tue Nov 15, 2011 8:47 am
Hi all,
Some infos about the Audi S2 5 cyl 2,2L Turbo:
-Camshaft Position Sensor 1 tooth every 720°, Hall
-Crankshaft Speed Sensor 135 teeth every 360°, Magnetic
-Crankshaft Position Sensor 1 tooth every 360°, 62° BTDC Cyl#1, Magnetic
I use Cam Pos and Crank Speed, I assume i can try Mode 2...
Regards
Francois
insomnia
Re: Audi S2 5 cyl
Postby MarkMc on Fri Nov 25, 2011 8:41 am
Yes, mode 2 is what you need. You should still ALWAYS do a ref/sync capture to attach to emails/posts if you are asking this type of question.
Re: Audi S2 5 cyl
Postby insomnia on Fri Nov 25, 2011 11:05 am
Hi MarkMc,
i"m sorted now, firing order 12453
cam sensor hall, ref sensor mag, filtered at 0,5v, Crip 62° Mode 2 135 teeth and the engine start nice!
i remove the stock MAF, mount a MAP sensor 3 Bars, Done.
i go on the Dyno in a few days and look what the Turbo GT42 push under 2 Bars Boost...
Thank you.
insomnia
Users browsing this forum: Bing [Bot] and 12 guests
