Bosch 0 227 100 211
Re: Bosch 0 227 100 211
Postby harold on Fri Aug 29, 2008 4:38 am
That is a very good idea, I didnot think of that, thankyou
harold
Postby harold on Thu Sep 18, 2008 9:39 pm
ok, thanks for your help, the motor has survived and appears to be fine, the only change has been the ignition module.
harold
Postby AaronM on Fri Sep 19, 2008 10:02 pm
I would recommend performing a Rockwell test in this area on the head. I say this as heat does not dissipate very well in that particular area. We find heads become extremely soft especially after prolonged use or an overheat. Compare the area to that of a position completely away from the combustion chamber. Usually brinelling is present if they are soft. You will be very surprised. I hope this helps. Chevs are real common for in in the centre two cylinders on each bank.
AaronM
Postby harold on Mon Sep 22, 2008 7:43 pm
Hi AaronM, I have not heard of a Rockwell test, can you explain what it is please
harold
Postby AaronM on Mon Sep 22, 2008 10:25 pm
The Rockwell test is a hardness test. The procedure consists of an extremely hard tip (diamond I would imagine) being loaded onto the test piece (cylinder head in this case) The ammount the tip goes in basically determines how hard the test piece is. This will leave a small dot like a centre punch mark in your material. BE CAREFUL. Obviously there are standards to the force that is implied and the machines must be calibrated. There are three common scales used. A, B and C scale. C is primarily used for metals. Most good engineering companies will have one
AaronM
Previous
Users browsing this forum: No registered users and 31 guests
