034EFI DIS Coil
Re: 034EFI DIS Coil
Postby jalai on Wed Nov 09, 2011 9:10 am
This MotoTron IGN-COIL-001 IS NOT the same as 034EFI / IGN-1A coil.
All measured values in this document are wrong for 034EFI coil.
jalai
Re: 034EFI DIS Coil
Postby insomnia on Wed Nov 09, 2011 12:31 pm
OOuuuuppsss!!!!
if this is wrong, Do you have the other values?
insomnia
Re: 034EFI DIS Coil
Postby Scott@FP on Thu Nov 10, 2011 5:19 am
I was gonna say that MotoTron doc it looks like their version is a very low ohm primary winding with reduced dwell time ceiling. The IGN-1A you can start at 2mS at normal system voltages and go up to ~6mS at high loads at less than 75% DC for brief periods.
Scott@FP
Re: 034EFI DIS Coil
Postby insomnia on Thu Nov 10, 2011 9:18 am
Ok guys,
i follow this way, thank you for sharing the infos.
Francois
insomnia
Previous
