I have setup the GPSL5 unit with my Motec M400 and am getting the GPS speed data properly. Looking at the logging it appears to work pretty well. I would like to use this speed information as ground speed for gear detection and also traction control.
Is this possible, I don't have the advanced options upgrade at the moment, but I dont really want to pay for it if it won't work with the GPS. Currently I can't get gear detection to work as it seems to work of ground speed. I could wire the wheelspeed sensors to the motec, but I don't really see the need/benefit of it since the gps speed and rpm/gear should provide sufficient data. Since it's an awd car driven/non driven slip calculation will be a bit hard to work with I think. I really wanted to calculate slip from rpm/gear (driven speed) and gps speed (ground speed).
