5 bar map setup
5 bar map setup
Postby beefcake on Sat Oct 22, 2011 9:08 pm
ok ive just purchased the 5 bar unit from motec (53006) , now wondering how to set up the tables correctly .
1 , sensor calibration .. is that found in my "sensor setup" box , and if so i just set it to -1
2 , now it gets tricky :P , 0 pressure AD value ? , does that mean i go to the "sensor cal tables" and go into "manifold pressure" , and if correct the very first box (0) i enter the value 103 and then "interpolate horizontal row "
the ECU then makes its own numbers for all of the remaining boxes .
Is this correct and am i missing something
What is the *pressure AD value mean (500/895) , and where do i set it if need be in my M2R , as i cant find anything relevant in my setup tables to enter the numbers ?
thanks brad
PB of 10.01@138 mph
http://www.youtube.com/watch?v=w2k_idn71ro
beefcake
Re: 5 bar map setup
Postby beefcake on Mon Oct 24, 2011 9:32 pm
also do i change my load sites to 0~500 setting as well , i previously had it on 330
PB of 10.01@138 mph
beefcake
Re: 5 bar map setup
Postby MarkMc on Tue Oct 25, 2011 3:31 pm
Hi Beefcake,
You enter the 103A/D value under 0Kpa and 895A/D under the 500Kpa table site (all the way at the end). If you interploate the ECU will fill in the numbers linearly between the first (0Kpa) and last (500Kpa) sites in the table. That's all you need to do. So enter both end values first before interpolating.
A/D: this is a computer way of looking at voltage. If you want to know a voltage from A/D counts it goes liek this. The inputs into the ECUs are 10 bit resolution meaning the 0-5v sinal is divided into 1024 steps (2 to the power 10). So 895 A/D's is (895/1024)x5v = 4.37v.
Re: 5 bar map setup
Postby beefcake on Tue Oct 25, 2011 9:27 pm
thanks a lot for taking the time to reply , i can imagine the pile of requests you would have from us types :lol:
So i could assume i have my point 1 correct, and all i have to do now is re do my A/d value interpol, It makes sense now you explain it that way, and looking at your data sheet i got with it .
Also my extra question , does my load sites table need to be put @ 500 in general setup menu to suit the 500kpa map sensor :)
PB of 10.01@138 mph
beefcake
Re: 5 bar map setup
Postby MarkMc on Fri Oct 28, 2011 4:56 pm
Yes. :)
Re: 5 bar map setup
Postby beefcake on Fri Oct 28, 2011 7:31 pm
thanks mate :)
PB of 10.01@138 mph
beefcake
Re: 5 bar map setup
Postby Sal on Thu Nov 24, 2011 1:17 pm
so for a gm style 4 bar sensor the same applies (instead of 500 it'd be 400)... and where do i check the load table that you speak about??
Sal
Re: 5 bar map setup
Postby beefcake on Thu Nov 24, 2011 10:07 pm
the load table (actually called "load sites selection" ) setting is in your "general setup" section , you can then set it from there :)
PB of 10.01@138 mph
beefcake
Re: 5 bar map setup
Postby Sal on Sat Nov 26, 2011 7:07 am
so another question...if i was using a 3 bar sensor... and changed to a 4 bar....would all the map change?
Sal
Re: 5 bar map setup
Postby stevieturbo on Sat Nov 26, 2011 9:33 am
Sal wrote:so another question...if i was using a 3 bar sensor... and changed to a 4 bar....would all the map change?
The map will not change unless you change it.
It will remain mapped exactly as it was before. Anything over 3 bar ( absolute )you will need to create and tune
stevieturbo
