I do have M800 PnP and I like to use the
1. Gear change ignition cut
2. Traction control
3. Clutch
4. Gear Shift
5. Anti Lag
6. Nitrous
All of those needs Dig input which I have only one available. E8xx has 6 dig inputs and according to the manual dig input 5-6 can be used as switched inputs. It would be great if those dig 1-6 can be used as switched inputs and accessed by the Mx00 ecu manager
Plus more resolution to table like the Injector battery compensation, Main Fuel table, Ignition timing table, etc.
thanks
