Progress!!
Last weekend fitted up the wideband and wired in a map sensor...
as you can see below... Toyota tipping it all in above 3000rpm since 1978...
- mixtures.JPG (106.54 KiB) Viewed 18871 times
swaped engine temp to an AV in and it seems ok, may still fit a stand alone delco sensors for ET and AIT...
managed to get it to idle with the motec controlling fuel so very happy with that!
next on the list set up a dummy coil and ignitor hooked up to the M800 and with the factory ecu running the engine locked at 10deg advance I should be able to dial the motec CRIP in easily to match the 10deg.
once thats done i'll do more work on the fuel map and then build the IGF simulator to keep the stock ecu happy before letting the m800 run the igniton...
