RC Servo Control
RC Servo Control
Postby lpettipa on Sat Sep 03, 2011 4:32 am
I want to control an RC servo using an aux output on an ADL3. The RC servo requires a duty cycle control with fixed frequency (I think). Square wave, 3-5V. Power for the RC servo will be from a battery.
An aux out cycles the ground signal. I need to cycle the voltage. How can I do this? (If I had an ECU I think this would be simple as they have voltage outputs).
Thanks in advance.
Leigh
lpettipa
Re: RC Servo Control
Postby DuaneM on Fri Sep 09, 2011 3:46 pm
You need to wire a pull-up resistor between the Aux output and a 5V supply on your dash. Use a 1k, 4k7, or 10k resistor. This will feed 5V to the servo which is pulled to ground by the Aux output, giving the required square wave.
Most RC servos work on a small pulse width between 1mS and 2mS in length for their full range of movement. The repetition rate (or frequency) is not critical, just the pulse width. You can set an Aux output to Duty Cycle Control at 50Hz , and use a look up table to generate the correct duty cycle.
Effectively you need a minimum duty cycle at 50Hz of 5% (ie 1mS) and a maximum duty cycle at 50Hz of 10% (ie 2mS) for the full range of movement, so a look up table will help ensure that you don't run outside of these duty cycle limits. Most RC servos drop out if the pulse width is wrong.
DuaneM
Postby lpettipa on Sat Sep 10, 2011 10:53 pm
Thanks Duane, that should do the trick!
lpettipa
Postby Mazi on Wed Sep 14, 2011 12:18 am
Some servos like older Futaba 9k series with metal gears are frequency sensitive. If the frequency is to high (over 70Hz) it will start to rotate and HW will be damaged. 20ms pulse to pulse or 50Hz will be just fine. Some servos will need 1.6ms pulse for center position.
Mazi
Return to ADL3, SDL3 and CDL3
Users browsing this forum: No registered users and 34 guests
