I never want to use AV3 for Mass Air Flow, and AV6 for EGT. Any chance to rename the channel? Or are
these channels blocked only on this functions?
Any advice?
Thank you
insomnia wrote:Ok but in "adjust, sensors input, i cannot click on delete or change, the lines are grey...
what's the trick??
MarkMc wrote:There will never be any oportunity to change channel names in the M84, it is a replacement for the M4 and M48 and not a Hundred series ECU.
Compared to the M4 and M48 it is an extremely good thing, especially with Lambda and Logging thrown in.
I repeat....it is not a hundered series ECU....if you want all the fruit of a hundred series ECU, that's what you need to buy.
