Chris wrote:Yes you may use the GT101 as an appropriate wheel speed sensor with a M800 ecu. The magnetic ones will not work with the input types of the M800 for wheel speed, but you could attempt to use one of our magnetic to hall effect adapters. We have 4 different versions of it, depending on your need and sensors. It would probably be easier to use our adapter than change all the wiring for the other sensors.
