I have an M4 in a group A Celica st165. The original group A ECU's from Toyota had two trim knobs:
-fuel from -2% to +4% in 4 clicks
-max boost from 2 to 3bar absolute pressure in even 8clicks.
How would you normally wire these to the M4? The knobs are digital: 2 outputs for 4 clicks and 3 to cater for 8positions. You could wire them to resistors to make a 0-5V signal out of it to save on inputs.
I want to replace the fuel trim with ignition trim to prevent for knocking. And keep the boost control.
Thanks!
