Find these webinars on You Tube http://www.youtube.com/user/MoTeCAustralia
AUG 4, 2011: Configuring a 9 Position Switch for Driver Compensations
JUL 25, 2011: Boost Control Set Up - Part 2: Closed Loop PLUS Important Supplement
JUL 14, 2011: Overview of MoTeC Technical Terms - ECUs
JUN 9, 2011: Smart Things You Can Do With an ECU and a GPS
MAY 19, 2011: Boost Control Set Up - Part 1: Open Loop
MAY 12, 2011: How to Set Up Cam Control Part 1
APR 14, 2011: What is Cam Control?
APR 11, 2011: Helpful Hints on Boost Control Plumbing
APR 1, 2011: How to Calibrate ECU Inputs
MAR 31, 2011: How to Choose the Right ECU
FEB 3, 2011: Ref/Sync Troubleshooting
JAN 13, 2011: How to Test ECU Outputs
DEC 14, 2010: How to Set Up Ref/Sync Parameters in an ECU
DEC 2, 2010: How to Connect Other Devices to an M84 ECU
NOV 25, 2010: Introduction to Ref/Sync Triggering
NOV 18, 2010: Getting to Know the New M84 ECU
NOV 12, 2010: What is CAN?
NOV 4, 2010: How to Configure a MoTeC Shift Light Module (SLM) with an ECU
SEP 30, 2010: Understanding the Differences Between ECU Inputs
SEP 2, 2010: Retrieving and Sending Logged Data Files
(Trial) AUG 19, 2010: ECU Installation and Tuning Basics for PWCs
