Little help with M84 spec /options please
Re: Little help with M84 spec /options please
Postby stevieturbo on Sat Aug 06, 2011 8:33 pm
For coil near plug, dont overloook the LS1/2/3/6/7 etc series of coils as used on General Motors V8's
They are all very powerful and have built in ignitors. You would have no problems with them. They are also pretty reasonably priced, new or second hand.
stevieturbo
Postby Scott@FP on Mon Aug 08, 2011 7:59 am
Holmz wrote:
Scott@FP wrote:...
If you insist on COP the Bosch P100-T is highly recommended and has the high current IGBT transistor built in, direct hookup to ECU ign outputs.
I found a gem there in the Bosch catalogue - do you have any place that you recommend to get the coils that are more motorsports oriented?
I got the first 4 that were imported officially to the US 3 years ago, prices have come down quite a bit since then. PM me for specifics.
Scott@FP
Postby tricky on Wed Aug 10, 2011 7:59 am
Thanks for all the input guys, I think I'll provisonaly look at using these p100-t's. It's probably better to get something that easilly does the job rather than a coil that could be marginal at higher levels.
Rich
tricky
Previous
Return to M84 ECUs
