New on forum/Toyota
New on forum/Toyota
Postby 1600hf on Thu Jul 14, 2011 9:59 pm
I have an M4 in a group A Celica st165. The original group A ECU's from Toyota had two trim knobs:
-fuel from -2% to +4% in 4 clicks
-max boost from 2 to 3bar absolute pressure in even 8clicks.
How would you normally wire these to the M4? The knobs are digital: 2 outputs for 4 clicks and 3 to cater for 8positions. You could wire them to resistors to make a 0-5V signal out of it to save on inputs.
I want to replace the fuel trim with ignition trim to prevent for knocking. And keep the boost control.
Thanks!
1600hf
Re: New on forum/Toyota
Postby MarkMc on Wed Aug 03, 2011 4:23 pm
The M4 has a spare analogue volt and analogue temp input that you could wire two potentiometers to, we do not use the digital inputs like Toyota did. You could then calibrate the pots to be for a boost compensation and for an ignition compensation. You could even have one pot as a combination to alter fuel and ignition together.
Postby 1600hf on Wed Aug 03, 2011 10:35 pm
That would work! Thanks.
I would want to keep the original knobs. Is there a simple way to turn the digital signal into a useful analogue one?
The outputs of the 8 step one is 000,001,010,....111.
1600hf
Postby Allan L on Tue Aug 09, 2011 12:33 pm
1600hf wrote:That would work! Thanks.
got a photo of the switch itself?
Allan L
Postby MarkMc on Thu Aug 11, 2011 5:48 pm
I would just replace the internals with a proper potentiometer.
Users browsing this forum: No registered users and 27 guests
