What fuel pressure sender
Postby Mr ganbatte on Thu Jul 28, 2011 4:02 pm
Hi guys,
I am running an intank 280l/hr pump and a Bosch 044 external on a surge tank.
This is on an RB26 motor, 800 cc injectors and a M800 ecu
Which is the correct fuel pressure sender to get for my set up.
Not sure on the fuel rail pressure at present .
Would the Motec 100 psi honeywell sensor do the job and what burst pressure is it rated at.
Recommendations appreciated
Mr ganbatte
Re: What fuel pressure sender
Postby MarkMc on Fri Jul 29, 2011 9:56 am
The 100psi sensor will be fine, their burst pressure is something like 10x.
Postby Mr ganbatte on Fri Jul 29, 2011 2:28 pm
Thanks Mark
Mr ganbatte
Postby Scott@FP on Sat Jul 30, 2011 5:24 am
If you are going to have a comp table for fuel pressure target error correction I would suggest using an absolute sensor to match the 'zero' of your MAP sensor, if just monitoring pressure gauge or sealed gauge would be fine.
Scott@FP
Users browsing this forum: No registered users and 36 guests
