Fast_Moto wrote:I am calculating lean angle using the arctan of the lateral accelration calculated from GPS heading and speed information. As part of the process, I need to do some low-pass filtering. Does it make sense to do an initial filter of the GPS heading which is used in subsequent calculations or just do a filter of the final output of the calculations.
Fast_Moto wrote:The gyro/accelerometer IMU I am using does a pretty decent job (e-Lean) using a Kalman filter helps keep the error acumulation lower. But, as nobody has used this sensor with a Motec system, I am still identifying certain issues.
As part of my testing, I am using the GPS based lateral acceleration as a check (not as the primary input). However, using the derivative of the GPS heading as the rate of angular rotation causes the a big spike when the heading changes from 0 to 360. That is something that I am having difficulty filtering without overfiltering the rest.
Do you have any suggestions for that?
PaulGM wrote:Fast_Moto,
As I only know of one customer using this device, I'm guessing I have already worked on this with you a little. E-mail if you need help with specifics.
