M84 when the TP gets lower,engine stops
Postby hitlvyuan on Tue Jul 19, 2011 7:23 pm
Our engine can run smoothly with diffdrent TPs.
But after the TP gets to 0%,it always stop.
Temperature >100 ℃
lambda<0.85
Now I have a problem with M84 ECU.
When I change the throttle position from 80% to 0(idle) at about 110 ℃,the engine always can not idle.
It always runs at idle speed(1300RPM) for a few seconds,then the speed down to 1000 and 700 and lower,then stops.
And the lamdad that time is 0.8 and sometime even is 0.7.
But when I start the engine,it can idle normally.
I have changed the engine temperature cmop and reduced the fuel at idle.
So I think I should set up the fuel decel.
But I do not know how to set it up.
Please help me.
And do you think what results in this? :)
Thank you!
hitlvyuan
Re: M84 when the TP gets lower,engine stops
Postby Blu302 on Wed Jul 27, 2011 7:56 pm
Read this thread for Fuel decel clamp and all the related settings:
http://www.motec.com.au/forum/viewtopic.php?f=10&t=1470&st=0&sk=t&sd=a&hilit=decel
With the TP, is the engine still getting enough air to idle? ie through idle valve etc
Blu302
Blu302
Postby hitlvyuan on Thu Jul 28, 2011 11:52 am
Blu302 wrote:Read this thread for Fuel decel clamp and all the related settings:
Thank you very much.
It seems like that when the engine with high temperature,the idle is hard to keep running.
hitlvyuan
Return to M84 ECUs
