MDD and SLM
MDD and SLM
Postby MANDALAY on Sun Apr 17, 2011 3:15 pm
This is a MR2 and i wanted something that would look stock.
So to mount my MDD i bought an OEM toyota GPS head unit. Not interested in the GBS so i made a housing to mount the MDD into it.
The head unit because of the distance it sticks out because of the tilt function i made new brackets to recess it.
So ive made the ends and attached to the holding brackets. They have oversized holes so as i can move them so as to sit flush with the plastic bezel
So now its of to be anodized flat black.
Then ill start the wiring then make a new aluminium box to house the MoTec MDD in the spot where the TOM TOM is.
So out goes the GPS unit and in goes my MoTec MMD.
So ill sand blast it for the plastic texture look then anodize it.
Also i made a hosing for my SLM
I got my MoTec SLM ( leds ) bracket finally finished.
I decided to mount it to the bottom plastic surround of the cluster.
Its in an aluminum housing.
The housing has a counter sunk piece of perspex so as to look flush.
Now with all the other aluminum pieces i can get then sand blasted to the same texture finish of the ABS plastic then anodize them.
Just showing how its all put together
So rapped that i got the angle correct.
MANDALAY
Re: MDD and SLM
Postby Blu302 on Tue Apr 26, 2011 5:06 pm
Great work with the CNC machining. I bet it took a few hours.
Blu302
Blu302
Re: MDD and SLM
Postby MANDALAY on Mon Jul 25, 2011 10:37 pm
Well i repositioned the SLM on the steering wheel.
Changed the spiral clock with another MR2 one with extra pins to connect the SLM
MANDALAY
Re: MDD and SLM
Postby Chris Wilson on Tue Jul 26, 2011 8:55 pm
Lovely workmanship, you are a patient man, I would hate you to see my PLM installation ;)
Chris Wilson
Return to Customer Projects
