Motec M8
Motec M8
Postby RSR-WRC on Thu May 12, 2011 1:04 pm
wondering if anyone could help?
i have just been given a motec M8 to use in my 97 sti,
can i get a wire adapta loom to plug in my my car loom?
can i get the soft ware to tune the ecu?
can i still get the cable to the laptop to talk to the ecu?
can anyone give me any info on the ecu its self?
serial #9301025
James
RSR-WRC
Re: Motec M8
Postby MarkMc on Wed Jul 06, 2011 10:33 am
Hi James,
The software is avaiable from out web site under old versions. It is a bit hard to tell what version is actually installed in the ECU so it is best to just download the last version, when you try to connect to the ECU it will tell you if there is a mismatch and what version you need.
All MoTeC dealers will be able to get you a PCI cable. if you laptop does not have a serial port you will need a USB to serial adaptor as well. It is probably best to instal the current version of M4 software as well so that you have the latest communications software, do this after you have insatlled the M8 software.
If you email me at mark.mccoy@motec.com.au I should be able to find a wiring diagram for an M48 which should be of help, there were not many M8s put on Stis but it will work.
Return to Old ECUs
