ECU Manager Software Update Suggestion Thread
Postby whrdnsx on Sat Jul 02, 2011 9:04 pm
As Jamie A from Motec mentioned they are in the process of considering updates for the ECU manager software.
please put forward your suggestions to help improve the current software.
my suggestions are;
1. Block number changes, to be able to highlight a number of cells & simply adjust all with + or - increment.
2. Ghost trace
3. On Site box on the Map table instead of off to the side. so the site cursor/box would show on the map table wether inbetween 2x sites or 4 x sites ect. Hope that made sense.
4. I2 Datalog & ECU manager map table trace. ie if both I2 & ECU manager open as the cursor follows a datalog trace the corresponding site would be highlighted on ECU manager Fuel/Ign tables.
whrdnsx
Re: ECU Manager Software Update Suggestion Thread
Postby FoxPerformance on Sun Jul 03, 2011 4:58 am
I'd like to see all the editable parameters/channels etc. able to be configured in a window with "drop down" tree type menus..
also I'd like to see in i2 the ability to configure a grid for your fuel map with the x an y positions for RPM and throttle pos. and the cells get populated by lamba figures and or the % that the lamda reading is off your target as well as a cut and paste option and a special "multiply special" so you can then take that % number and just do a quick add/sub/multiply into you base fuel map. it would need a filter of some type where the cell doesn't get updated when logging unless the value changes are stable for a few cell hits
Ben Fox
www.FOXPERFORMANCEENGINES.com
(719)570-9595
FoxPerformance
Postby stevieturbo on Sun Jul 03, 2011 8:03 am
fast up/down block changes as per other thread.
Ghost trace, coloured, asterisk or otherwise.
Screen layout lock ( I often grab the main map with the mouse pad and move it by accident lol )
stevieturbo
Postby whrdnsx on Sun Jul 03, 2011 6:02 pm
To be able to toggle between loaded Configs.
whrdnsx
Postby whrdnsx on Sun Jul 03, 2011 6:04 pm
also I'd like to see in i2 the ability to configure a grid for your fuel map with the x an y positions for RPM and throttle pos. and the cells get populated by lamba figures and or the % that the lamda reading is off your target as well as a cut and paste option and a special "multiply special" so you can then take that % number and just do a quick add/sub/multiply into you base fuel map. it would need a filter of some type where the cell doesn't get updated when logging unless the value changes are stable for a few cell hits[/quote]
That's a good one. +1
whrdnsx
Postby JamieA on Mon Jul 04, 2011 10:25 am
Thanks guys. This is much appreciated.
I am just taking notes...
-Jamie
JamieA
Postby Blu302 on Fri Jul 08, 2011 6:38 pm
whrdnsx wrote:also I'd like to see in i2 the ability to configure a grid for your fuel map with the x an y positions for RPM and throttle pos. and the cells get populated by lamba figures and or the % that the lamda reading is off your target as well as a cut and paste option and a special "multiply special" so you can then take that % number and just do a quick add/sub/multiply into you base fuel map. it would need a filter of some type where the cell doesn't get updated when logging unless the value changes are stable for a few cell hits
That's a good one. +1[/quote]
Make it +2
Blu302
Blu302
Postby kako911 on Tue Jul 12, 2011 2:34 am
+3
kako911
Postby bing on Sat Jul 23, 2011 5:27 am
Ctrl-Z Undo and Pause Function Please..
bing
Postby JamieA on Mon Jul 25, 2011 10:50 am
Pause....
Can you please explain that one?
do you mean pause the live readings?
JamieA
