LTC CAN Bus Messages
Discussion and support for the MoTeC PLM and LTC's
Postby Mazi on Thu May 05, 2011 9:04 pm
There is also Message 3, ID-2 available but not documented.
Unknown messages are sent out from LTC on address 1CF8xxxx.
Any info available?
Mazi
Re: LTC CAN Bus Messages
Postby JamieA on Tue Jun 21, 2011 5:56 pm
It is a debug message for Motec diagnostic use only.
you wont need to worry about it.
what version are you using, as I thought it wasnt meant to send it.
regards..
Jamie
JamieA
Postby Mazi on Wed Jun 22, 2011 1:11 pm
Jamie
Firmware version is 1.04C
Mazi
Postby Powertrain on Fri Dec 04, 2020 11:51 pm
Hi there,
it is possible to setup the LTC Controller without sending the Motec diagnostic messages?
When yes, how to do this?
Powertrain
Postby adrian on Mon Dec 07, 2020 10:16 am
No it isn't possible to turn the messages off, they are used for PC communications.
The address range of the messages is 0x1CF80000 to 0x1CF8FFFF.
Return to PLM & LTC
