GPS and lean angle
Re: GPS and lean angle
Postby Fast_Moto on Tue May 31, 2011 5:33 am
Have you made any progress on this?
I have a sensor that provides roll and yaw rates and longitudinal and lateral acceleration over CAN. Is it possible to do the necessary filtering and calculations to get the lean angle in the ACL? Has anyone here done this already?
Thanks.
Fast_Moto
Postby Holmz on Tue May 31, 2011 11:15 pm
Fast_Moto wrote:Have you made any progress on this?
NO.
You really need 3-axis or both gyro rates as well as acceleration.
You also need magnetometers or if it is moving then the occasional GPS.
IMUs have 3x(acceleration, gyro, and magnetometers) just for that reason, otherwise you do not have enough data.
Fast_Moto wrote:.. Has anyone here done this already?
I have been through most of it.
If you export the data into .cvs format then you can read it into MATLAB, or have a .dll to look at the data post-facto. If you need it in real-time, then you will have to do it in the ACL, or in something else before it goes to the ACL.
Do you need it in real-time
You need something known once in a while - like a GPS position.
Holmz
Postby Holmz on Sun Sep 11, 2011 12:26 pm
The video link is interesting.
http://www.youtube.com/watch?v=rCOt78MB5vM
Seems like they are using gyros on a gimbaled platform which stabilize the video... (Passively)
Rather than using "rate gyros" to drive motors for the platform to be held level (Actively).
Holmz
Previous
Return to ADL3, SDL3 and CDL3
