Fuel level on ADL
Fuel level on ADL
Postby sacaboy on Mon Feb 21, 2011 4:19 am
Hi mate!
How can I connect the fuel level sensor to ADL in EVO 9?
I would like the ADL write the fuel level!
Anybody?
Best regards
Sacaboy
sacaboy
Re: Fuel level on ADL
Postby OmarK on Mon Feb 28, 2011 9:08 am
As you may know, the fuel level sensor is not connected to the M800 PNP. So you should be able to wire this sensor into the ADL. If it is a resistive sensor then you will need to measure the resistance with different fuel levels and use an AT input into the ADL with the appropriate input calibration... If it is a varaiable voltage sensor then you will use an AV input... you will need a wiring diagram of the car and multimeter... hope this helps :)
OmarK
Postby ahobbs on Wed May 25, 2011 3:30 pm
http://www.ironcanyonmotorsports.com/pr ... ucts_id=28
instructions are on that site as well
T1racedevelopment.com
ahobbs
Return to ADL, ADL2 and SDL
