knock module
SKM and OKM
knock module
Postby r.hellenbrand on Fri Sep 05, 2008 11:27 pm
Did see, in the latest catalogue, there is a knock detection module available.
Where can I find information about this module?
Is there software available to make full knock control?
In the latest M800 software, it is only possible to log knock signals, none algorithm is possible.
Thanks,
Ron
r.hellenbrand
Re: knock module
Postby Dragon on Mon Sep 08, 2008 2:31 pm
Yes, it is possible to do individual cylinder knock control with the SKM.
What ECU are you using?
Dragon
Re: knock module
Postby r.hellenbrand on Tue Sep 09, 2008 11:47 pm
I'm using a motec M800.
Is the software a beta release, latest software knock control isn't possible!
Thanks,
Ron
r.hellenbrand
Re: knock module
Postby Martin on Wed Sep 10, 2008 3:19 am
Yes its beta,
i Think it might be available Nov 1st? Motec?
Re: knock module
Postby r.hellenbrand on Wed Sep 10, 2008 8:41 pm
Where can I get the beta software?
Thanks,
Ron
r.hellenbrand
Re: knock module
Postby stevieturbo on Thu Sep 11, 2008 4:51 am
What is the SKM ?
stevieturbo
Re: knock module
Postby Dragon on Thu Sep 11, 2008 11:15 am
Standalone Knock Module for M800.
TCK is a for M800 based plug-in boards.
Dragon
Re: knock module
Postby SprinterTRD on Thu Sep 11, 2008 2:14 pm
I dont think the knock modules will not be available to the general public like ECU's or other MoTeC products.
You need to go through a dealer that has been trained on them and get them to set it up for you.
SprinterTRD
Re: knock module
Postby Apex Speed Tech on Sat Sep 27, 2008 5:18 am
I see this in the new software. Just to clarify:
1. Is the knock module required to do knock control?
2. Any updates on availability?
3. What kind of sensors will be supported.
Thanks,
Neel
Neel Vasavada
Apex Speed Technology
2931 S. Sepulveda Blvd Suite F
Los Angeles, CA 90064
310.314.2005
www.apexspeedtech.com
Apex Speed Tech
Re: knock module
Postby Dragon on Mon Sep 29, 2008 12:04 pm
The SKM can deal with both narrow and wide band knock sensors.
You will need a spare ignition output channel configured as "knock window".
Dragon
Return to Knock Modules
