by MarkMc on Fri Apr 29, 2011 6:05 pm
The engine temp will always be a degree or two higher because the engine block is a very good heat sink and will take days to cool right off. This is normal.
I'm not sure what the problem is with the MAP and fuel pressure is. The MAP with the engine off will be the Barometric pressure (about 100Kpa but depending on where you are) and the fuel pressure should be zero but this can depend on your fuel system and if you have been runnign the engine or not.
