- 11APR11.e35
- Current config
- (72 KiB) Downloaded 1055 times
I have an issue with my Lambda sensor set up on M800.
Sensor is Bosch 0 258 017 066/67 LSU 4.9 (originally ford application)
Once the warm up is complete the value goes straight to 1.75.
No error in the diagnostics.
No exhaust leak.
Engine idling with no miss or excessivley lean/rich mixture.
Engine at 2500rpm=no change.
No exhaust leaks.
Config file and Logged data file attached.
Many thanks
Steve
