Chase cam on M84
Chase cam on M84
Postby SMChipTuning on Thu Apr 14, 2011 6:15 pm
Hi
Can I use Chase cam PDR100 rev5 on M84 ?
I need "only" RPM and TPS value from M84 on video.
How I can setup M84 for this job ?
In this manual http://www.motec.com/filedownload.php/M ... docid=3087 I can't find any information about wiring conection and setup motec software for this.I found pin out for DTM8 connector,but I don't know how to setup M84 to chase cam over RS232 TX-RX line.
Can someone explain how to connect the chase cam and setup soft ?
SMChipTuning
Re: Chase cam on M84
Postby MarkMc on Fri Apr 15, 2011 3:54 pm
The M84 does not send out any RS232. The communications for the M84 is locked to only MoTeC devices.
Postby SMChipTuning on Fri Apr 15, 2011 10:51 pm
Thanks for answer.
OK,If the M84 is not support this,can I use SDL RS232 output to connect this cam ?
SMChipTuning
Postby MarkMc on Thu Apr 21, 2011 5:48 pm
I think it has been done. Since we make our own video system we have not put to much effort into supporting other brand system.
Return to M84 ECUs
