Raw input values
SKM and OKM
Raw input values
Postby MichaelLee on Fri Mar 25, 2011 4:13 pm
I have see the Raw input values of SKM are 3V to 4V when the engine not running, that the engine background noise very high (the background noise levels are 70% when engine running with not knock). How can I setup to make Raw input values lower voltage at the engine not running?
The knock sensor is Bosch 0 261 231 217
MichaelLee
Re: Raw input values
Postby MarkMc on Tue May 03, 2011 5:42 pm
Hi, what values of gain do you have? What basic values do you have when the engine is idling?
Return to Knock Modules
