when you say channel Mr holmz do you mean making a new channel in the i2 chart to read it, or elsewhere
Im sure my answers back from the dealer will reflect your ideas for me in this thread, thanks again guys
Scott@FP wrote:You can't use the default selection PSI (Gauge) in the main I2 to read +/-, you must write a math, for instance kpaA * 14.5 -14.5 for PSI gauge with zero at 100 KpaA. 1 kpa = .145 PSI, but where the proper place to set your "zero" reference is up for debate. 100 kpaA is lower than a STD atmosphere by most definitions.
