accel clamp chart recorder
Postby Lip on Sat Aug 30, 2008 3:31 am
I am using ecu manager 3.41g. When using a chart recorder for accel clamp the chart just bounces up and down with no reference to the values I get when I logg and look at it with i2 software.
Can I do something to make the ecu-software charting real values?
Thanks Lip
acc clamp.JPG (41.26 KiB) Viewed 14809 times
Lip
Re: accel clamp chart recorder
Postby SprinterTRD on Sun Aug 31, 2008 8:01 pm
Looks like you have the sensitivity or ACC clamp cranked up too high or you have a problem with your TPS sensor
SprinterTRD
Postby Lip on Mon Sep 01, 2008 4:50 am
Hi sprintertrd,
I was thinking the same but the result is equal when I use just one value for clamp without using Y- or X- axis.
Furthermore the chart looks like it should when you logg it and watch it with i2-software. Maybe its a bug.
Could someone else try if the this chartrecorder works?
Thanks Lip
Lip
Postby RossB on Mon Sep 01, 2008 3:42 pm
I have checked this. There appears to be a problem with the way this channel is being reported by ECU Manager, not specifically by a chart recorder. The channel is working correctly within the ECU and is being reported correctly when logged. I will enter this in to our fault tracking system.
RossB
Postby Lip on Mon Sep 01, 2008 7:36 pm
Hi RossB, thank´s.
Lip
Lip
Users browsing this forum: Majestic-12 [Bot] and 21 guests
