Newbie Question
Newbie Question
Postby lmr motorsport on Sun Aug 31, 2008 8:39 pm
Hi guys, i have a 4age Engine running a Motec M4 i was wondering how i can determine if it is a M4 (DataSet 5 & DataSet3)?
lmr motorsport
Re: Newbie Question
Postby RossB on Mon Sep 01, 2008 2:59 pm
The ECU configuration file determines which data set is being transmitted. You will fing this in the Adjust Menu under General Setup/Miscellaneous Setup 2. The Telemetry Data set is the parameter that sets this, each data set is described in the Help menu.
RossB
Re: Newbie Question
Postby lmr motorsport on Mon Sep 01, 2008 5:31 pm
Thankyou for your help, i know understand it a bit more.
Cheers
lmr motorsport
