test outputs function in m400 software
Postby andym69 on Sun Aug 31, 2008 7:24 am
anyone had any probs with the test output function in ecu manager software? it worked in the earlier versions but since we changed too version 3.3 and 3.4 it wont work, any ideas, fixes or nightmares? cheers, andy
andym69
Re: test outputs function in m400 software
Postby Apex Speed Tech on Sun Aug 31, 2008 9:31 am
I did an injector test with an M880 running V3.4 just Thursday and it worked fine.
Neel Vasavada
Apex Speed Technology
Los Angeles, CA 90064
310.314.2005
www.apexspeedtech.com
Apex Speed Tech
Postby IDP on Sun Aug 31, 2008 4:46 pm
I recall the test outputs not working on an M400.
Works fine on M800 and M880.
It was some time ago now, I figured it would have been sorted.
IDP
Postby NathanS on Mon Sep 01, 2008 7:17 am
Hi Andy,
The problem with the test outputs not working on the M400/M600 was fixed in V3.32E, could you let me know in which versions of software you have tried to do the output tests?
Could you email me or post the ECU config file you have been using when trying to test the outputs and I can test this for you?
nskinner@moteceurope.co.uk
NathanS
