M4 with HP laptop can't see some word on graph page.
Postby torque on Thu Sep 30, 2010 7:26 pm
Hi
I use M4 and install software on HP laptop but when I go to graph page. It can't see the numeral on table.
XX00, XX00 But when I open with IMB no problem.
What's is problem?
Can you help me to settle this one?
DOS run well with IBM only?
Thanks,
Numeral can't see it.
torque
Re: M4 with HP laptop can't see some word on graph page.
Postby torque on Fri Oct 01, 2010 12:11 pm
Anyone can help me??
torque
Postby Motorsport Eng. on Tue Feb 01, 2011 7:08 pm
have you solved?
We have seen it on some laptop as well.... :? :?
regards
Andrea Torniero
www.motorsportengineering.com
Motorsport Eng.
Postby Holmz on Tue Feb 01, 2011 7:41 pm
Guessing here...
But it looks like there are some English type fonts that you might not have on the machine.
Not sure if that is the case, or how you add more language fonts if it is.
Holmz
Postby SprinterTRD on Wed Feb 02, 2011 7:07 am
The problem is with the video system not supporting the resolution correctly. Unless there is a later video driver there is no fix for the problem.
SprinterTRD
Postby OmarK on Wed Feb 02, 2011 1:24 pm
I'm not sure what version of Windows you are using but you could read about this fix here and test if this helps you.
http://www.motec.com.au/forum/viewtopic.php?f=10&t=1152
OmarK
