Can you explain me step by step how to mount a GPS G1 on a M800 and you to config the right setup.
I only use a M800, on a motorcycle. Speed ,track drawing, lap time, etc....what's avaible or not?
Thank you for all infos.
Francois
insomnia wrote:Thank you Mark for your answer.
I order the GPS now. If i understand i can see the lap time in I2 but no possible to transmit in the CAN Bus?
With an other bike we mount a GPS and a display from AIM (MXL) and they have a software named GPS manager and you can select the different sectors on the track, and you see live lap timing. Can i use a BR2 wired in the M800
and send the live lap time with CAN Bus in the MXL Display?
Cheers
Francois
insomnia wrote:Thanks Holmz,
I try to make the right choice for the hardware we need. I try to jump between MoTeC and a factory Kit ECU and for sure this give us a lot of issues with MoTeC, no live timing for the rider, no gps speed, and very bad not all the laps with lap timing but only one big lap If i need to use BR2 for MoTeC and an other systeme for the AIM dash it's very difficult to work in a short training session...To much wire to much solution to much software and to much issues....
Mazi wrote:Mark
Is there any way to send slow 1PPS GPS data to M800 ECU via CAN just for proximately position logging? My RS232 port is already used by MDC.
