ADL3 template for 07 Subaru STI?
Postby 07-EDM-STI on Thu Dec 09, 2010 3:22 pm
I'm planning to buy ADL3 and SDC2 for my 07 STI. Does ADL3 have a template for 07 STI?
Will the ADL3 be able to display the DCCD position and the fuel level that the oem dash/gauge cluster display? thanks
07-EDM-STI
Re: ADL3 template for 07 Subaru STI?
Postby RossB on Tue Dec 14, 2010 8:08 am
You do not need to use a specific data set for the Subaru, you can simply use the data set for M800 V3.3+ and set the M800 to send out the ADL data set.
Alternatively you can set up your own custom data sets in the M800. These can be exported to ADL3 using the export function in the M800 Custom Data Set setup.
You can only display DCCD information if you are using the MoTeC SDC which can be connected to the M800 via RS232.
The fuel guage would require a direct connection to the ADL.
RossB
Postby 07-EDM-STI on Tue Dec 14, 2010 10:34 am
Thanks a lot Ross :D
07-EDM-STI
Return to ADL3, SDL3 and CDL3
