ALS EVO 8 Gr.N
ALS EVO 8 Gr.N
Postby racer on Mon Nov 29, 2010 7:47 pm
I tryed to open the trottlebody arround 30% and have real agressive ALS ( hold pressure arround 1,0 bar )
( In Gr.N i can not run any valve or kicker )
But at partload it is not possible to drive the car.
Is there anything what i can do to become a better partload ?
Also when i would like do drive without ALS there is no partload.
I can see all the time fuelcut active .
I find that i have something to change on the main ignition ( retard ).
Is there any who can help ? may be with a startup file ?
racer
Re: ALS EVO 8 Gr.N
Postby yotamhks on Tue Dec 07, 2010 5:04 pm
partload driving is not possible with ALS and without ALS? then the problem isn't ALS..
if you see the overrun fuel cutout active you might need to set it again. notice that it has minimum throttle
to be active. usually set to 2% and you can set it ever lower. also check if your throttle sensor is calibrated.
yotamhks
Re: ALS EVO 8 Gr.N
Postby Mazi on Thu Dec 09, 2010 12:08 am
Just drive your car as an diesel without touching a throttle pedal. Change only 1st-3rd-5th gear and try to stay below 2000RPM. To decelerate or maintain top speed you have to use the brakes. It is not easy for the first time but... Repetitio est mater studiorum :D
Mazi
Re: ALS EVO 8 Gr.N
Postby racer on Mon Dec 13, 2010 11:41 pm
Many thanks for the info´s.
best reg.
racer
Return to M800 Plug-In ECUs
