previously, SLM was working with direct connection to my M800.. red wire to A26, Black wire to A10, White (Can HI) to B23 and Green (Can Low) to B24. I didnt add a terminating resistor at the SLM side...but it worked. (lucky?)
after my garage took out my wiring etc for my engine overhaul etc... long story short... now my SLM isnt working :p
i've done the following..
- used new wires for the SLM to ECU connections...
- twisted the green and white wires to make them self shielding
- added a 100 ohm 0.25W resistor between the green and white wires at the SLM's DTM plug side..
- SLM setup and table all untouched..
- CAN setup done...Can 2 Data -> 13, Can 2 address -> 41
- at the DTM plug, there is 12V and ground. There is continuity for the green and white wires
but its still not working!!!
anyone got any other ideas? :~(
